Clears the user-defined display string from one or more ports.
port_list |
Specifies one or more ports or slots and ports. |
N/A.
This command removes the display string that you configured using the configure ports display-string command.
The following command clears the user-defined display string from port 4 on a switch:
unconfigure ports 4 display-string
